24v input issue <resolved, short to ground by foil>
Re: 24v input issue
Looks like the green LED on the power supply goes off too. Short to ground somewhere. Does it do the same when connecting to the other 24v in? What is on the other side where you have the mounting screws going through? A stand off body or a washer that is shorting something to ground on the back side?
Scott
Re: 24v input issue
i agree, power off and take these off the board.Sword wrote: ↑Wed Mar 06, 2024 11:20 pm Looks like the green LED on the power supply goes off too. Short to ground somewhere. Does it do the same when connecting to the other 24v in? What is on the other side where you have the mounting screws going through? A stand off body or a washer that is shorting something to ground on the back side?
Re: 24v input issue
Thank you for your help guys! I found a tiny piece of what looks wire shielding foil jammed under the input terminal block and touch the ground under the mounting screws. Lights are all on now, I’ll finish testing the inputs this evening.
Re: 24v input issue
thanks for reporting back.
Re: 24v input issue <resolved, short to ground by foil>
I must say that is a pretty good power supply to still be working!
Gary
Gary
