Trak Mill Rebuild
- CNC Control System Serial Number: cnc12 Mill Pro E0623483321F-0412225912,CNC Router Pro E0623479658B-1022203857
Trak Mill Rebuild
Hello Everyone; Help
This is a Trak mill that I have been working on for a while. It's fully functional, very accurate and I am very happy to have chosen Centroid Acorn to be
the controller. I have also done a router (total rebuild AXYZ 4008) with the Centroid Acorn Controller, clearpath motors and all great.
I do have 2 issues with the mill:
a) error during the com_stress_test
b) lower end voltage on the 0-10Vdc to drive the VFD is high (1.7 instead of a max of 1.66)
my two cents worth tells me that the controller could be bad, I replaced the Communication Cable 3 different ones, PC Tuner, Ping in dos mode
went through the remaining windows setup and they work but the "con_stress_test fails.
Regardless of these two issues the Mill works, does not stall or stop.
I have posted some screen shots and pictures of the Mill see link below
https://photos.google.com/album/AF1QipM ... u58CQGDpP0
for the b issue I need the accuracy in order to set up correctly the rigid tapping.
Spindle set up at 3000RPM 1.746, 3.380, 6.68 and 9.98
Re: Trak Mill Rebuild
google photo album link is bad
fyi rigid tapping doesn't rely on programmed spindle speed for its moves.. it relies on the spindle encoder to let cnc12 know the position of the spindle.Angelo DiCenso wrote: ↑Fri Mar 01, 2024 4:21 pm Hello Everyone; Help
so while it is nice to get the VFD calibrated so when you request M3S640 the spindle spins as close to 640 as possible. it completely does not matter if the spindle is actually spinning 620 or 650 etc... the tapping will work just fine.
what kind of PC are you using?
com stress test is failing since the error log has tons of pc /mpu resend errors
01-2024 14:07:40 944 MPU requested resend # 45
(4) 03-01-2024 14:07:40 946 PC resending # 1912
(4) 03-01-2024 14:08:06 944 MPU requested resend # 46
(4) 03-01-2024 14:08:06 946 PC resending # 1913
(4) 03-01-2024 14:08:06 946 PC resending # 1914
(4) 03-01-2024 14:08:10 944 MPU requested resend # 47
(4) 03-01-2024 14:08:10 946 PC resending # 1916
(4) 03-01-2024 14:08:12 944 MPU requested resend # 48
(4) 03-01-2024 14:08:12 946 PC resending # 1918
(4) 03-01-2024 14:08:35 944 MPU requested resend # 49
(4) 03-01-2024 14:08:35 946 PC resending # 1920
(4) 03-01-2024 14:08:51 944 MPU requested resend # 50
(4) 03-01-2024 14:08:51 946 PC resending # 1922
(4) 03-01-2024 14:08:52 944 MPU requested resend # 51
(4) 03-01-2024 14:08:52 946 PC resending # 1924
(4) 03-01-2024 14:08:59 944 MPU requested resend # 52
(4) 03-01-2024 14:08:59 946 PC resending # 1926
(4) 03-01-2024 14:09:07 944 MPU requested resend # 53
(4) 03-01-2024 14:09:07 946 PC resending # 1928
(4) 03-01-2024 14:09:08 944 MPU requested resend # 54
(4) 03-01-2024 14:09:08 946 PC resending # 1929
(4) 03-01-2024 14:09:08 946 PC resending # 1930
(4) 03-01-2024 14:09:09 944 MPU requested resend # 55
(4) 03-01-2024 14:09:09 946 PC resending # 1932
(1) 03-01-2024 14:09:16 Creating report...
There certainly are a lot of comm errors in the msg_log.txt:
Are all of the Ethernet cables you've tried shielded?
Link to TB270 on troubleshooting Comm Errors: https://www.centroidcnc.com/dealersuppo ... ds/270.pdf
Domenic
have you tried adjusting the NIC adapter to 100 full duplex?
does this adapter have intel drivers? are they updated from the mfg website?
go over all the details in TB270 and TB309
and if you can't solve it with those docs
here is the how to solve com error thread.https://centroidcncforum.com/viewtopic.php?f=61&t=1451
info on proper vfd termination and adding a .1uf cap is here.
https://centroidcncforum.com/viewtopic.php?f=63&t=5398
