So I accidentally connected +24VDC to EN2 and smoke came out while doing the bench test.... Now none of the screw terminal outputs work and all the relays on the relay card are stuck in the on (green) state. Activating a relay output just makes the green led dim a bit.
The heartbeat/communications are still good and motors still move (connected thru the DB25)
Question is can I purchase just an acorn board minus the BBG and use my BBG? or do I have to buy a whole new kit?
The smoke came out
Re: The smoke came out
Guess its cheaper than a new one, especially after the price increase. Is the board serial# the label/barcode on the DB25?
The serial number for Acorn boards are the last 4 digits in the SystemID, found in the first F1-Setup page.
Domenic
thats gonna be tough to do with a burnt up board....dpascucci_support wrote: ↑Fri Mar 01, 2024 5:09 pm The serial number for Acorn boards are the last 4 digits in the SystemID, found in the first F1-Setup page.
the bar code is fine.. take a photo or type it out.
The board still works, just the outputs are nonfunctional, I'll get the system ID. Thanks
