baldor cc22529 dc servo motor info needed <which clearpath to use?>
Re: baldor cc22529 dc servo motor info needed
please post a photo album of the machine so we can see the whole thing
cnckeith wrote:torque should be in the 1000-1200 oz-in in range
I assume you mean instantaneous peak torque.
Those numbers translate to 62.5 - 75.0 in-lb, which is 2-3x the continuous stall torque that a knee mill with 10 revs/inch typically needs.
jpalmer
Post by jpalmer »
Right now the mill is kinda buried in the shop. I'll get some pictures posted as soon as I can and make a new thread "Tree journeyman 210 retrofit"
cncsnw wrote: Thu Feb 29, 2024 10:52 pm
when we put steppers on machines like this with the CNC4 they were rated as 1350 oz-in max t motors and had a nema 42 frame
is this machine 10 TPI?
jpalmer
Post by jpalmer »
5 tpi
jpalmer
Post by jpalmer »
I think these sdsk clearpath motors will probably be my best choice as far as being the closest to the baldor motors that it has in it.
CPM-SDSK-3426P-RLN
CPM-SDSK-3441D-RLN
I'm going to call Aimee back at teknic today with the info she requested and see what she suggests. I will update with her recommendations later
jpalmer
Post by jpalmer »
Is that just a two-axis machine?
If it is 3-axis, where is the Z?
you may want to contact RE Combat and see which CP he used on his B port knee mill conversion
alternatively
