vfd control question
Posted: Tue Feb 27, 2024 1:13 pm
Hi,
I'm retrofitting Acorn into an Industrial CNC 4x8 router table. It has a Fuling 220v VFD driving a 2.2kw spindle.
I bought the parts required for a latching circuit as shown by BuildBug at
Under this setup, there are stop and start momentary buttons controlling the coil in the 220v contactor. Both spindle vfd and drive power supplies are cut off during an estop.
Now that I have received my Acorn, I see that I can do this differently as Acorn and CNC12 must have control ability from the operators console.
Diagram s15117 shows how to use the relays within the contactor estop circuit to control the spindle vfd using vfd common, vfd forward, vfd reverse, vfd reset. Elsewhere I would also wire 10v analog speed control from H8 and the 220v supply.
Question1: Does this circuit shut down the vfd during an estop?
Question2: Is there any reason why I shouldn't split the 220v power after the contactor such that both the drive power supplies and the vfd get shut off during an estop?
Question 3: Maybe the spin direction controls do not apply to a router? Do I need them?
Question 4: I assume this circuit allows me to initiate an estop from the software (ie dont have to hit one of the physical big red mushroom buttons on the machine?
