Hi everyone,
I wanted to provide an update on my Dyna Myte 3000 lathe retrofit project. While making progress, I am facing an issue with my new DMM servo and driver setup on the spindle. When I try to control the spindle manually from the VCP spindle speed buttons, I have to turn the RPM up to about 100% for the spindle to turn on. However, it then starts to speed up and causes a spindle fault. I am unsure of what could be causing this issue, but I believe it must be a setting or something because the spindle I replaced with this DMM setup had the same issue.
I have attached my Wizard files, DMM Wiring Diagram, and report. If anyone has any insight into what might be happening here, I would truly appreciate it.
Lee
Spindle Control Issue
- CNC Control System Serial Number: 98F07B936216-0504237156
- Wizard info.pdf
- (1.31 MiB) Downloaded 10 times
- report_98F07B92168A-1103237630_2024-01-31_11-47-01.zip
- (821.41 KiB) Downloaded 9 times
-Lee
New River, AZ
New River, AZ
Re: Spindle Control Issue
did anyone every get one of these dyn4's working as a spindle motor?
I know Gary has done it with a Leadshine AC servo successfully
and Uwe did it with JMC AC servo successfully
but i can't remember anyone posting success with this dyn4 as spindle motor?
