Spindle bench test not showing full text
The spindle benchtest does not show the full text. Maybe it needs adjusting in the software or is it my monitor resolution?
Re: Spindle bench test not showing full text
you are looking at the g code preview, run the job by pressing cycle start to run the spindle benchtest
Click Edit to read the full text.
No.
Text is longer and there are more than 11 lines with infos.
It is a preview not more, for full read, use editor.
That is the way it is.
