I have added a laser pointer to my CNC router. It projects a + onto the workpiece. This is offset from the tool tip and I would like to write a macro to add to my pendant to set the tool position. Shortly I will post a picture of the setup if this is not clear. I think that there might be a macro already in the program that would come pretty close to doing what I want, but I cannot find it.
The macro would do this
set Z height to 3"
Pause for input
receive input
set X and Y axis to zero
move tool to X=3.0, Y=3.16
Pause for input
Need help writing macro
Re: Need help writing macro
If you load the "router" version of CNC12 there's a button and a sample macro for this already. You set up your "offset" in the wizard on the "input devices setup" page. There's a section labeled "cross hair laser setup". I believe the oem macro is mfunc76 if you want to manually edit.
I have the exact same setup with a cross hair laser and it's programmed to button 1 of the WMPG as I use it a lot. My macro is slightly different than the stock one but it does the same thing. My laser is mounted to the fixed, backplate for the Z axis and it focused to the spoilboard so no need to move my Z axis when using the macro. You would simply add that Z move into your custom macro.
My crosshair laser and macro is set up is similar to Shawn's. I've added the option to choose what WCS (1-6) I would like to set as well. The offsets are hard coded, but as Shawn states, the latest versions now have the crosshair laser offset option in the Wizard and a macro to go with.
; Filename: plcmacro4.mac
; Description: User Customizable Macro, currently set for laser alignment
; Notes:
; Requires: Machine home must be set prior to use.
; Please see TB300 for tips on writing custom macros.
IF #50010 ;Prevent lookahead from parsing past here
;M225 #100 "This is an example macro run from the Macro2 button on the Centroid CWP-4 MPG\nThe macro is named MPGmacro2.mac and can be found\nin the \cncm\system directory.\nEdit it to include the desired functionality. Press Cycle Start to Exit"
N100 ;Insert your code between N100 and N1000
; Set XY to Laser
#101 = 1 ; Default WCS G54
#102 = -3.2702 ; X offset to Laser (pos or neg)
#103 = -4.089 ; Y offset to laser (pos or neg)
#104 = 4 ; Length of time to wait for M225 message
#105 = 0 ; "NO" to setting another location
M5 ; Turn off spindle
M200 "SET XY LOCATION WITH LASER?\nCycle Start to continue\nCycle Cancel to get out of here"
M25 ; Raise Z to machine home
N200
M224 #101 "What WCS would you like to set? (Enter 1-6)"
IF [#101 < 1] || [#101 > 6] THEN GOTO 200
E#101 ; Set the chosen WCS
M94/29 ;Turn on laser
M200 "MOVE CROSSHAIRS TO DESIRED LOCATION\nPress Cycle Start when finished"
G91 G0 X[#102] Y[#103]
G90
G92 X0 Y0
G4 P 0.5
M95/29 ;Turn off laser
M225 #104 "XY LOCATION SET FOR WCS #%.0f" #101
N300
;M224 #105 "Would you like to set another location? (0 = NO, 1 = YES)"
;IF #105 == 0 THEN GOTO 1000
;IF #105 == 1 THEN GOTO 200 ELSE GOTO 1000
N1000 ; end
Scott
That's a great option/addition Scott if you use multiple work coordinates. I always use G54 for every project but I know there are those who use multiple so a nice added feature to your macro.
I tend to leave G54 at the table corner (which is also machine coord) for those times I may put a whole or partial sheet on the table or when surfacing the table, and 2-6 wherever else I may have something set up with a jig or in a corner clamping frame. The laser is for non critical alignment, and a 5" x 5" corner plate with a bore for setting exact with the probe app.
Scott
Thank you!
That certainly makes sense and a good plan of attack if using multiple WCS. I don't really cut material or parts where I need to know EXACTLY where the corner is so the cross hair laser gets it "close enough" for me. I think this is why I haven't tried the probe app yet. I don't need anything that precise as I cut parts from whole sheets. I have a 3D probe that I use to find the center of holes in aircraft panels and do wall following with and the Centroid interface works great for what I need.Sword wrote: ↑Sun Jan 28, 2024 3:41 pm I tend to leave G54 at the table corner (which is also machine coord) for those times I may put a whole or partial sheet on the table or when surfacing the table, and 2-6 wherever else I may have something set up with a jig or in a corner clamping frame. The laser is for non critical alignment, and a 5" x 5" corner plate with a bore for setting exact with the probe app.
