Centroid V5.06 Lathe Graph not showing
Has anybody else had the problem with the lathe graph not showing the toolpaths?
- report_E0623470B40F-0819215108_2024-01-10_14-06-49.zip
- (855.05 KiB) Downloaded 16 times
Re: Centroid V5.06 Lathe Graph not showing
(4) 01-10-2024 13:51:37 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:51:37 9042 Probe Cleared
(4) 01-10-2024 13:51:38 9042 Probe Cleared
(4) 01-10-2024 13:51:39 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:51:39 9042 Probe Cleared
(4) 01-10-2024 13:51:40 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:51:40 9042 Probe Cleared
(4) 01-10-2024 13:51:51 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:51:51 9042 Probe Cleared
(4) 01-10-2024 13:51:53 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:51:53 9042 Probe Cleared
(4) 01-10-2024 13:52:00 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:01 9042 Probe Cleared
(4) 01-10-2024 13:52:18 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:18 9042 Probe Cleared
(4) 01-10-2024 13:52:19 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:19 9042 Probe Cleared
(4) 01-10-2024 13:52:20 9042 Probe Cleared
(4) 01-10-2024 13:52:21 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:27 9042 Probe Cleared
(4) 01-10-2024 13:52:28 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:29 9042 Probe Cleared
(4) 01-10-2024 13:52:32 8040 WARNING: PROBE TRIPPED
(4) 01-10-2024 13:52:33 9042 Probe Cleared
(1) 01-10-2024 13:54:45 204 Exiting CNC...Normal Exit (66)
(1) 01-10-2024 13:55:05 199 CNC Started
(1) 01-10-2024 13:55:11 CNC12 Lathe v5.06
(4) 01-10-2024 13:55:11 9033 Reset Initiated, Press Reset to Clear
(4) 01-10-2024 13:55:14 4032 Reset Cleared
(1) 01-10-2024 13:58:37 204 Exiting CNC...Normal Exit (66)
(1) 01-10-2024 13:59:16 199 CNC Started
(1) 01-10-2024 13:59:22 CNC12 Lathe v5.06
(4) 01-10-2024 13:59:22 9033 Reset Initiated, Press Reset to Clear
(4) 01-10-2024 13:59:25 4032 Reset Cleared
(1) 01-10-2024 14:01:04 204 Exiting CNC...Normal Exit (66)
(1) 01-10-2024 14:01:28 199 CNC Started
(1) 01-10-2024 14:01:34 CNC12 Lathe v5.06
(4) 01-10-2024 14:01:34 9033 Reset Initiated, Press Reset to Clear
(4) 01-10-2024 14:01:37 4032 Reset Cleared
(1) 01-10-2024 14:06:49 Creating report...
So what have these results got to do with the Graph not showing the tool paths.
Axis movement is inhibited while the probe is tripped.
Funnily enough, I was doing a small job yesterday and checked the graph and it was not there - blank? But was working last time used....
The photo was taken when the lathe was turning the part. I updated the software from V5.06 to V5.08 Now the graph is working showing the toolpaths.
your error logs are telling you that CNC12 thinks there is a probe tripped. therefore the spindle won't turn on, therefore there is no movement, therefore there is no run time graph.
eliminate the probe input in the wizard or configure it correctly.
Those probe tripped are from when i was setting up the tools with the probe. The graph photo was taken when the program was running. It was a bug in V5.06 It is working in V5.08
I'm not aware of a bug in 5.06 that does that.
