Hi , as acorn don't use the servo motor as servo ,
I want to understand what is the relation between step dir in cnc12 and the electronic gear in the servo drive ?
Playing with the electronic gear would it change the motor beaviours when it time to do fine detail ?
And the pulse amount 100 000 or 400 000 or else would change the beaviours of the aka servo motor ?
step and dir vs electronic gear
Re: step and dir vs electronic gear
No reason to play with electronic gearing in the driver for Acorn.
Ok then what should be the setup for servo motor driver should be 1:1 ? I have a 10:1 before , on what variable should I play with for having the same speed as previous ? step /direction number or what else , please informe me .
If you have a 5mm spindle and 2:1 gear reduction, dial in 2.5mm per Rev in the Wizard, thats all.
