Ether1616 Output boards?
- CNC Control System Serial Number: 20D7787C45AB-0819226470 - 98F07B6F97F8-0623237343
Does the Ether1616 need the 2 x Output Boards to be connected or can they be left off? I need the inputs, but not the outputs and panel space is limited.
Thx
Ian
Ian
Re: Ether1616 Output boards?
As long as you do not need the outputs you can leave the relay modules disconnected..
Great, thank you!
Thx
Ian
Ian
