I have an old core-xy 3d printer it uses all linear rails and I am looking to convert it to a cnc router, Can the Acorn use core-xy kinematics?
Thank you
core-xy kinematics
- CNC Control System Serial Number: 0035FF98BF3B-0325225816
Re: core-xy kinematics
Note that a 3D printer has virtually no stress and little weight on the head when printing. A CNC machine has a lot of stress during cutting operations. I'd guess that a core X-Y printer wouldn't have the gumption to handle the stresses or even the weight of the router.
If it's one used to build concrete homes, maybe. A standard FDM printer, probably not.
Agree that it's not up to the task. The issue is the comparatively enormous side loads it has to contend with, while the core XY (or any 3D printer) is built for basically zero side loading. In short, it'll vibrate itself to death really fast.
Previous hobby, building hard core sports cars. See http://midlana.com/ and http://kimini.com/
- CNC Control System Serial Number: E062346A1C67-0716214939
Yes, I agree, not a contender at all.
If on the other hand you attached a tool that doesn't impart stresses on the machine, like a laser, you could probably rig something up.
The other question about core X-Y being supported, no idea.
