4 linear scales on router with Acorn6 ?
While constructing a precision router with software paired Y, I have a question if it is possible to use scales on both y axis for closed loop?
Re: 4 linear scales on router with Acorn6 ?
I believe there is a planned add on board for the acorn 6 that will allow 3 more scales for a total of 6.
I know the Encoder Expansion is in the shop, a total of 9 with it.CNCMaryland wrote: ↑Wed Oct 04, 2023 8:52 am I believe there is a planned add on board for the acorn 6 that will allow 3 more scales for a total of 6.
https://shopcentroidcnc.com/shop/cnc-ac ... nsion-kit/
But my question was will a scale work with a soft paired Y axis and will it work with auto square...
We do have an encoder expansion board for ACORN6 that adds 6 encoder ports. It works well with scales and all.CNCMaryland wrote: ↑Wed Oct 04, 2023 8:52 am I believe there is a planned add on board for the acorn 6 that will allow 3 more scales for a total of 6.
I do not know if we have support for multiple scales on software paired axes. I'll see if I can find someone that does know.
We do not currently support using multiple scales for paired axes and I am unaware of any plans to implement that. I did a little testing with ACORN6/ENCEXP12 and a single scale on a software paired Y a while back and it should work well enough.
- CNC Control System Serial Number: 0035FF8FEB5F-0708203490
SO what is the point of all the encoder inputs if you aren't planning on using them to their full potential??? Makes no sense.
Thanks, not what I was hoping for, but it saves me the cost for one scale and the expansion boardcentroid467 wrote: ↑Wed Oct 04, 2023 12:42 pm We do not currently support using multiple scales for paired axes and I am unaware of any plans to implement that. I did a little testing with ACORN6/ENCEXP12 and a single scale on a software paired Y a while back and it should work well enough.
![Laughing :lol:](./images/smilies/icon_lol.gif)
But to make sure, screw compensation will work on the paired axis?
Multiple screws on the same axis can not be independently compensated.
