Hi All,
I was wondering if anyone has a working mill/turn post processor for a c axis lathe with live tools. I did have a working PP that outputs XZC C axis moves (no Y axis) but I updated to a new machine and now I can't find the file. Worse yet is I can't remember how I modified the code or even if I started with centroid turn, centroid mill or even a fraunc variant. Hoping someone has a version that's close even if I have to modify a little, it will be easier than starting over. It seems all the info I had on XZC outputs has gone missing too.
Cheers all.
Fusion C axis Lathe post processor
- CNC Control System Serial Number: 0035FF8FEB5F-0708203490
Re: Fusion C axis Lathe post processor
You have a xzc post processor? Where did you get it from? Did you make it yourself?
Any chance you could share a copy?
- CNC Control System Serial Number: None
I did but I upgraded to a new computer and have lost it in the process. I am now re-writing a new version that I will save in multiple locations. I was hoping to not have to and get a copy from someone so I am not reinventing the wheel but it doesn’t seem to be available. I will update here when I am done but it will take a fair while. I don’t have a lot of time and I am not great with code
My version is here, works well for my setup.
https://centroidcncforum.com/viewtopic.php?f=66&t=7936
Awesome, thanks for the link. Don't know why the search function did not show up that thread.....
