Installed version 5 over the weekend. Today I decided to use the virtual control panel in 4.82. So I replaced the version 5 VCP folder in the "Resources" folder with the VCP folder from V4.82. All is good EXCEPT I don't have the RESET button or anything else below column 10 on the virtual control panel.
So i powered down and replaced the original vcp folder from V5.x back in the RESOURCES folder as it was originally. The vcp folder from V4.82 was removed from the RESOURCES folder prior to placing the original vcp folder(V5.x).
I still had nothing below column 10 when CNC12 rebooted. Any ideas??
Jr
Reverting to VCP in version 4.82
- CNC Control System Serial Number: F045DA798AE4-1119181352
- report_F045DA798AE4-1119181352_2023-06-05_15-58-56.zip
- (779.65 KiB) Downloaded 1 time
Re: Reverting to VCP in version 4.82
in one sentence. if you have a custom VCP.
edit the new v5.0+ VCP with your custom VCP edits.
- don't just copy over the entire VCP folder. (v5.0 has features that v4.82 doesn't)
- do copy over the individual button folders and any corresponding macros
i loaded your VCP folder from the report.zip you posted, i dont' see any custom buttons?
do you have a customized VCP in v4.82? if so post a report.zip from v4.82
Scott thank you for that. I totally forgot about reading that a few weeks ago.
Jr
Jr
