Can you please tell when these parts will be available?
This year or next?
Can you tell if it is possible to use a main spindle encoder in full closed loop with Acorn 6?
In C axis operation.
Thanks for the information
Stephan
When will it be?
Re: When will it be?
the AcornSix encoder expansion board is available now in limited quantities, i'm taking photos and getting it up on the website this week.
part #15330 has been assigned. will start selling in beta mode this week.
adds 6 more encoder ports that can be used for encoders, scale or MPG's
I thank you for your feedback
I thought it would take longer, so I converted my machine to linear rails.
I grind all parts of Z on a surface grinder.
All parts of X were milled on a DMG Morie 5 axis.
I equipped all axles with ball screws.....
Today I tested everything.
My parts have a maximum deviation of 0.02mm but mostly 0.01mm.
Without changing the tool table.
The result is the same when milling in the lathe.
Therefore, I no longer need these upgrades.
Thank you anyway for your information.
Best regards Stephan
