Made a mounting bracket for my Lenovo M910q ThinkCentre PC. I know a number of people use them as CNC PCs so hopefully this might be useful to somebody.
The bracket fits a PC that is 180mm wide by 34.75mm high by 183.5mm long. It allows mounting to a plate above or below as it fits both ways to the PC. PC slides in form the rear and clips in place.
There is also an optional DIN Rail Mount that clips into the screw holes on the bracket (needs 2). The bracket holes are symmetrical so you can mount it either Vertically or Horizontally on the Rail.
The forum wouldn't allow me to upload the files as .stl, so I renamed them as .txt. To use them just replace the .txt with .stl.
Lenovo Tiny PC Mounting Bracket .stl file
- CNC Control System Serial Number: 20D7787C45AB-0819226470 - 98F07B6F97F8-0623237343
- M910q Mounting Bracket DIN Clip.txt
- (338.17 KiB) Downloaded 1 time
- M910q Mounting Bracket.txt
- (1.41 MiB) Downloaded 1 time
Thx
Ian
Ian
Re: Lenovo Tiny PC Mounting Bracket .stl file
cool, thanks for posting. -keith
