I decided to rearrange tool numbers as some items that I used often were at the back of the rack...One of the items I changed was my touch probe. When I got back to work I found that my probe was acting weird and I need to get some stuff done, so I used my favorite edge finder - the one that used to click when it was at the point of contact...well it's gone...I lost my edge finding skills 9-(. But the point is... you need to CALIBRATE your probe. I use ProbeApp so it's easy .... The probe was Setting 0-0 offset from the corner by 0.500 in Y and Y...guess what diameter tool was reordered to where the probe landed...?
I have gotten so used to using the probe as it is so easy AND it's more accurate than my second favorite edge finder...
HTH
changing tool numbers...always learning >>Probe Calibration!!!
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Re: changing tool numbers...always learning >>Probe Calibration!!!
Keep in mind that CNC12 needs to know the T# of your Touch Probe for probing to work properly. So if you assign the Touch Probe to a different T#, you need to adjust CNC12 Machine Parameter 12 with the newly assigned T#.lavrgs wrote: ↑Sat May 13, 2023 12:19 am I decided to rearrange tool numbers as some items that I used often were at the back of the rack...One of the items I changed was my touch probe. When I got back to work I found that my probe was acting weird and I need to get some stuff done, so I used my favorite edge finder - the one that used to click when it was at the point of contact...well it's gone...I lost my edge finding skills 9-(. But the point is... you need to CALIBRATE your probe. I use ProbeApp so it's easy .... The probe was Setting 0-0 offset from the corner by 0.500 in Y and Y...guess what diameter tool was reordered to where the probe landed...?
HTH
-swissi
