It's me again, Clearpath losing/gaining steps <resolved, loose pulley>
Tlempicke
Re: It's me again, Clearpath losing/gaining steps
Post by Tlempicke »
Keith - you called it. Took the motor off of the machine and this is what I found.
Clearpath has a good write up on the subject of clamping Here
https://teknic.com/files/downloads/Secu ... Shafts.pdf
Tlempicke wrote: Sat Mar 25, 2023 1:56 pm Keith - you called it. Took the motor off of the machine and this is what I found.
Yep, if done right it works :D
Good PDF from teknic.
Despite what Teknic says about keyways this is my method of choice with some 648 Loctite and a set screw. I order my pulleys with a set screw over the top of the keyway so it does not mar the shaft as it only presses on the key. A drop or two of 648 and it's never coming apart or twisting unless you heat it back up. Never had one come loose or measured any backlash from it.
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
Always great when things get figured out.
Carnac the magnificent does it again.
scroll down bottom right of this page.
Loctite 620 i use it all the time.
