Threading via Intercon
ShaAli
Post by ShaAli »
Hello,
As I am learning to use Intercon, I was hoping if there is tutorial on how to do threading on mill with intercon ? Keith's part tutorial was very helpful in learning.
Thank you.
Re: Threading via Intercon
Tapping or helical thread milling?
ShaAli
Post by ShaAli »
Threading using endmills in the mill rather than a tap. Hope this make sense
Thank you for your help.
For thread milling, you must use threadmills.
This is Intercon for a single point threadmill, pretty simple to dial in.
Most of the thread mill manufacturers have a web page showing suggested feeds and speeds for their threadmills.
https://www.google.com/url?sa=t&source= ... 6mequNIj1I
Because this is circular motion, actual feeds are much faster than linear feed rates so you need to adjust feedrates accordingly.
Calculator for this task on the VCP is here:
https://centroidcncforum.com/viewtopic. ... tor#p65149
ShaAli
Post by ShaAli »
Thank you all for your valuable time and help.
