Unknown Fault stops job
- CNC Control System Serial Number: E0623464B717-0628226384
Not sure what caused the fault. Here is my report. If anyone can take a look and tell me what may have been the issue. Thanks, Much appreciated.
- report_E0623464B717-0628226384_2023-02-02_08-19-19.zip
- (812.71 KiB) Downloaded 6 times
Re: Unknown Fault stops job
Here is the last few error messages, it seems you have either a drive fault or a spindle fault at time:
(4) 01-31-2023 10:07:11 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 01-31-2023 10:07:11 9077 Tool Touch Off Cleared
(4) 01-31-2023 10:07:13 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 01-31-2023 10:07:13 9077 Tool Touch Off Cleared
(1) 01-31-2023 10:09:01 FAST_JOG_SELECTED
(1) 01-31-2023 10:09:09 SLOW_JOG_SELECTED
(1) 01-31-2023 17:40:20 SLOW_JOG_SELECTED
(4) 01-31-2023 17:44:27 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 17:44:28 9030 SPINDLE FAULT!
(4) 01-31-2023 17:44:55 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 17:44:59 9030 SPINDLE FAULT!
(4) 01-31-2023 17:45:01 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 17:45:01 9030 SPINDLE FAULT!
(4) 01-31-2023 17:45:07 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 17:45:07 9030 SPINDLE FAULT!
(1) 01-31-2023 17:45:23 204 Exiting CNC...Normal Exit (66)
(1) 01-31-2023 17:45:36 199 CNC Started
(4) 01-31-2023 17:45:40 9030 SPINDLE FAULT!
(1) 01-31-2023 17:45:42 CNC12 Acorn Router v4.82
(4) 01-31-2023 17:45:42 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 01-31-2023 17:45:42 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 17:45:45 4032 Reset Cleared
(4) 01-31-2023 17:45:49 907 Z axis travel exceeded
(4) 01-31-2023 17:46:29 907 Y axis travel exceeded
(4) 01-31-2023 17:46:34 907 Y axis travel exceeded
(1) 01-31-2023 17:46:41 407 X- limit (#50002) tripped
(1) 01-31-2023 17:46:47 407 Y- limit (#50003) tripped
(1) 01-31-2023 17:46:50 407 Z+ limit (#50001) tripped
(1) 01-31-2023 17:57:23 FAST_JOG_SELECTED
(1) 01-31-2023 17:57:24 SLOW_JOG_SELECTED
(1) 01-31-2023 17:57:25 FAST_JOG_SELECTED
(1) 01-31-2023 17:57:25 SLOW_JOG_SELECTED
(1) 01-31-2023 17:57:26 FAST_JOG_SELECTED
(1) 01-31-2023 17:57:27 SLOW_JOG_SELECTED
(1) 01-31-2023 17:57:27 FAST_JOG_SELECTED
(1) 01-31-2023 17:57:34 SLOW_JOG_SELECTED
(1) 01-31-2023 17:57:35 FAST_JOG_SELECTED
(1) 01-31-2023 17:58:42 407 X- limit (#50002) tripped
(1) 01-31-2023 17:59:02 407 Y- limit (#50003) tripped
(1) 01-31-2023 17:59:06 407 Z+ limit (#50001) tripped
(1) 01-31-2023 18:13:57 FAST_JOG_SELECTED
(4) 01-31-2023 18:14:12 9031 DRIVE FAULT!
(4) 01-31-2023 18:14:28 9033 Reset Initiated, Press Reset to Clear
(4) 01-31-2023 18:14:29 4032 Reset Cleared
(1) 01-31-2023 18:23:03 407 Z+ limit (#50001) tripped
(1) 01-31-2023 18:23:54 407 X- limit (#50002) tripped
(1) 01-31-2023 18:24:04 407 Y- limit (#50003) tripped
(1) 01-31-2023 18:24:09 407 Z+ limit (#50001) tripped
(1) 01-31-2023 18:42:26 FAST_JOG_SELECTED
(1) 01-31-2023 18:42:37 SLOW_JOG_SELECTED
(4) 01-31-2023 18:46:49 9030 SPINDLE FAULT!
(4) 02-01-2023 11:51:43 9033 Reset Initiated, Press Reset to Clear
(4) 02-01-2023 11:51:45 4032 Reset Cleared
(1) 02-01-2023 11:51:48 407 X- limit (#50002) tripped
(1) 02-01-2023 11:51:50 407 Y- limit (#50003) tripped
(1) 02-01-2023 11:51:53 407 Z+ limit (#50001) tripped
(4) 02-01-2023 11:52:09 9031 DRIVE FAULT!
(4) 02-01-2023 11:52:25 9033 Reset Initiated, Press Reset to Clear
(4) 02-01-2023 11:52:26 4032 Reset Cleared
(1) 02-01-2023 11:52:33 FAST_JOG_SELECTED
(1) 02-01-2023 11:52:35 407 Z+ limit (#50001) tripped
(4) 02-01-2023 11:52:36 9031 DRIVE FAULT!
(4) 02-01-2023 11:52:45 9033 Reset Initiated, Press Reset to Clear
(4) 02-01-2023 11:52:47 4032 Reset Cleared
(1) 02-01-2023 11:53:01 204 Exiting CNC...Normal Exit (66)
(1) 02-01-2023 11:53:41 199 CNC Started
(1) 02-01-2023 11:53:47 CNC12 Acorn Router v4.82
(4) 02-01-2023 11:53:47 9033 Reset Initiated, Press Reset to Clear
(4) 02-01-2023 11:53:52 4032 Reset Cleared
(1) 02-01-2023 11:55:03 407 X- limit (#50002) tripped
(1) 02-01-2023 11:56:01 407 Y- limit (#50003) tripped
(1) 02-01-2023 11:56:02 407 Z+ limit (#50001) tripped
(4) 02-01-2023 11:58:36 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 02-01-2023 11:58:36 9077 Tool Touch Off Cleared
(1) 02-01-2023 11:58:44 204 Exiting CNC...Normal Exit (66)
(1) 02-01-2023 11:59:02 199 CNC Started
(4) 02-01-2023 11:59:06 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 02-01-2023 11:59:08 CNC12 Acorn Router v4.82
(4) 02-01-2023 11:59:08 9033 Reset Initiated, Press Reset to Clear
(4) 02-01-2023 11:59:16 4032 Reset Cleared
(1) 02-01-2023 11:59:19 407 X- limit (#50002) tripped
(1) 02-01-2023 11:59:21 407 Y- limit (#50003) tripped
(1) 02-01-2023 11:59:23 407 Z+ limit (#50001) tripped
(1) 02-01-2023 17:34:10 FAST_JOG_SELECTED
(1) 02-01-2023 17:34:20 SLOW_JOG_SELECTED
(4) 02-02-2023 8:16:34 9033 Reset Initiated, Press Reset to Clear
(4) 02-02-2023 8:16:35 4032 Reset Cleared
(1) 02-02-2023 8:19:19 Creating report...
Thanks. The error on the screen said “Fault” and nothing else. If this time stamp is correct:
“ (4) 02-01-2023 11:59:06 9039 Software Exited, Cycle E-Stop/Reset to
Continue”
It is impossible that it happened because I wasn’t even near the machine at that time to exit the software.
Continue”
It appears that someone was at the machine only 30 seconds before doing a tool touchoff and a shutdown.
Very strange. I was the only one here and I did not do it. Absolutely impossible.
I wouldn't get hung up on the time stamp.
Those limit-tripped messages look like normal homing to me. They are at two-second intervals, which would be reasonable for homing from a parked position, and they come in the order specified in the cncm.hom file.
There do seem to be quite a lot of "9030 SPINDLE FAULT" messages, and a couple "9031 DRIVE FAULT" messages. Is there any indication that you are actually getting spindle drive or axis drive faults?
i stand corrected. thanks.
I will keep a closer watch on the Faults you mentioned to see if there is an actual Fault happening. Thanks!
