acorn with an old shopbot
Re: acorn with an old shopbot
luke wrote: Tue May 30, 2023 6:59 pm I'm back now after taking some time off. I just got back to the machine and still have not been able to solve the homing and z zeroing problems. I tried several different inputs with the tool touch off just as Scott mailed me and can not get it to stop the down movement. I did the alt I and when I touch the plate to the bit it triggers the light.
start with a good description, photos and a fresh report.zip so we can give you good advice.
http://centroidcncforum.com/viewtopic.php?f=60&t=1043
luke
Post by luke »
Ok here is the latest report. Most everything works other than the homing and Z zeroing.
luke wrote: Thu Jun 01, 2023 4:56 pm report_60E85B9CEC25-1214226725_2023-06-01_14-45-46.zipOk here is the latest report. Most everything works other than the homing and Z zeroing.
luke,
hello.
need more description on what you mean by homing and z zeroing doesn't work.
make a video of the issue so we can see what you are doing. -keith
the reports shows you are using windows 7. this OS is not supported.
use Windows 10 or 11 and follow the setup guide to configure Windows for CNC use.
Also the PC being used as a CNCPC does not meet the minimum required PC specs
review all the info on this page.
https://www.centroidcnc.com/centroid_di ... guide.html
this system has no chance of working properly without a new CNCPC , you can buy one for cheap that meets the min. req. here.
https://amzn.to/3lZMtwE
also set or get a 1920x1080 monitor
Reported Generated: Thu Jun 1 14:45:46 2023
MPU12 serial number: 60E85B9CEC25-1214226725
License: ACORN ROUTER PRO
Version: CNC12 Acorn Router v4.82
Machine Timers info
Power On : 000005.002
Job in Progress : 000001.198
Spindle Running : 000001.173
Since : 04/16/2023
Operating System info:
Edition : Windows 7 Home Premium
OS Build : 7601
Memory info:
Total physical memory : 4285853696
Available physical memory : 3029127168
Processor info:
Intel(R) Pentium(R) D CPU 2.80GHz
Number of cores : 2
Number of logical processors : 2
Display Size: Width 1680 Height 1050
z limit is tripped.
- could be incorrect wizard switch configuration, bad wiring, bad switch, switch dog not positioned correctly.
- remove the TT input (and any other probe inputs) and get basic things like homing working BEFORE adding accessories.
in general, add one thing at a time to the CNC controller and test as you go. avoid just 'hooking everything up" and then trying to debug, that method is doomed.
06-01-2023 14:22:42 4032 Reset Cleared
(1) 06-01-2023 14:24:06 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:15 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:16 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:42 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:51 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:52 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:54 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:55 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:24:56 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:03 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:05 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:06 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:10 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:20 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:22 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:23 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:24 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:26 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:27 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:28 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:29 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:32 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:33 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:34 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:37 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:38 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:25:44 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:26:22 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:26:36 199 CNC Started
(1) 06-01-2023 14:26:47 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:26:48 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:26:52 4032 Reset Cleared
(1) 06-01-2023 14:27:10 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:12 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:13 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:14 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:15 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:19 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:20 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:21 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:23 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:24 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:26 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:27 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:46 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:48 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:50 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:27:58 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:03 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:04 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:05 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:06 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:07 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:08 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:11 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:12 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:15 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:18 407 Z+ limit (#50001) tripped
(1) 06-01-2023 14:28:42 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:35:26 199 CNC Started
(1) 06-01-2023 14:35:35 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:35:35 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:35:38 4032 Reset Cleared
(1) 06-01-2023 14:35:58 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:36:52 199 CNC Started
(1) 06-01-2023 14:37:00 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:37:01 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:37:03 4032 Reset Cleared
(1) 06-01-2023 14:37:18 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:39:04 199 CNC Started
(1) 06-01-2023 14:39:12 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:39:12 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:39:16 4032 Reset Cleared
(4) 06-01-2023 14:41:01 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 06-01-2023 14:41:13 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:41:18 199 CNC Started
(4) 06-01-2023 14:41:22 8075 WARNING: TOOL TOUCH OFF TRIPPED
(1) 06-01-2023 14:41:27 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:41:27 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 06-01-2023 14:41:27 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:41:30 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 06-01-2023 14:41:44 9077 Tool Touch Off Cleared
(4) 06-01-2023 14:41:49 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 06-01-2023 14:43:25 9077 Tool Touch Off Cleared
(1) 06-01-2023 14:43:54 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2023 14:43:58 199 CNC Started
(4) 06-01-2023 14:44:02 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 06-01-2023 14:44:07 CNC12 Acorn Router v4.82
(4) 06-01-2023 14:44:07 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2023 14:44:10 4032 Reset Cleared
(4) 06-01-2023 14:44:43 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 06-01-2023 14:44:44 9077 Tool Touch Off Cleared
(4) 06-01-2023 14:44:45 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 06-01-2023 14:44:46 9077 Tool Touch Off Cleared
(4) 06-01-2023 14:44:48 8075 WARNING: TOOL TOUCH OFF TRIPPED
(4) 06-01-2023 14:44:49 9077 Tool Touch Off Cleared
(1) 06-01-2023 14:45:46 Creating report...
luke
Post by luke »
Ok here is what I did. I got a newer desktop and loaded cnc12 5.02 and loaded the settings I had before. when I go to home the machine it moves to the first limit and stops I can not get it to move off that switch but it will move in the Y and if I shut it down and manually move the x off the switch I can move the gantry using the buttons. I can not move the Z with the button but it will move with the MDI command. Back when version 5 was in trials I had the same problem. here is my report
report_60E85B9CEC25-1214226725_2023-06-05_18-02-57.zip
(794.52 KiB) Downloaded 6 times
Luke,
make a video of what you are doing.
sounds like the limit switches are not wired to the corresponding axis, for example sounds like X axis is moving to seek home but Y axis limit gets tripped.
currently this is how you have the system configured.
; #wizardregion Inputs
ThirdAxisHomeLimitOk IS INP1
FirstAxisHomeLimitOk IS INP2
SecondAxisHomeLimitOk IS INP3
ToolTouchOffDetect IS INP4
EStopOk IS INP8
; #endregion
where axis 1 = x, axis 2 = y, and axi 3 = Z.
do you have Z switch wired into input #1?
do you have X switch wired into input #2?
do you have Y wired into input #3?
(and are these prox switches or regular type switch? if prox what type? )
do this...start out with a MUCH simpler setup and use only Home Switch inputs and verify that the X switch is configure to the X axis etc.
wire all of them into one input and define that as "HomeAll"
like this. https://www.centroidcnc.com/dealersuppo ... 954.r5.pdf
this way you don't have to keep track of what switch goes with what axis!
verify each switch action before homing, use the PLC diagnostic app to observe the switch working with the input.
https://www.centroidcnc.com/centroid_di ... screen.pdf
also, edit the limit switch defeat xml file and change the skin number from 67 to 25.
Acorn v5.02 limit switch defeat VCP button got broken.
we were working on making things the same between Acorn and AcornSix and the Acorn limit defeat button got broken but it is and easy fix. applies to Acorn ONLY (not AcornSix)
If your Limit Switch Defeat button is not working, open the limit defeat button XML file and change the skin even number from 67 to 25
<vcp_button>
<skin_event_num>25</skin_event_num>
<plc_output>
<number>1109</number>
<color_on>#EC1C24</color_on>
<color_off>#81151C</color_off>
</plc_output>
</vcp_button>
save the file.
restart cnc12
and get a 1920x1080 monitor!
luke
Post by luke »
Is there a fix for the Z button not working
luke wrote: Mon Jun 05, 2023 8:30 pm Is there a fix for the Z button not working
i don't know what you mean, all Z axis buttons work. :D
need better description or better yet make a video. (or at least some photos)
did you do what i suggested in the post above?
