Page 1 of 4
2 Spindles AcornSix
Posted: Sat Jan 28, 2023 9:50 am
by Rensoc
The new Acorn Six board shows 2 analog outputs. Is this to operate 2 spindles independently?
Re: 2 Spindles AcornSix
Posted: Mon Jan 30, 2023 3:40 pm
yes with some initial limitations. such as no dual independent rigid tapping (that will be a future software feature.)
Posted: Tue Jan 31, 2023 10:24 am
by Rensoc
Thats great. This is very exciting! I just keep getting amazed by what Centroid is doing. Is there a screen shot of the control showing both spindle controls?
Posted: Tue Jan 31, 2023 2:30 pm
right now in v4.99 rev4 they are paired, so nothing to see.
Posted: Thu Feb 02, 2023 5:31 pm
by Rensoc
Will it work two separate motors in Beta? Or will I have to wait until full version is out? I'll just be turning on the second motor and setting a speed. I know I could do this cheaper with control outside of Acorn but I would rather not.
Posted: Fri Feb 03, 2023 4:07 pm
Rensoc wrote: Thu Feb 02, 2023 5:31 pm Will it work two separate motors in Beta? Or will I have to wait until full version is out? I'll just be turning on the second motor and setting a speed. I know I could do this cheaper with control outside of Acorn but I would rather not.
hi! please describe the specific functionality you are after.
Posted: Fri Feb 03, 2023 6:00 pm
by Rensoc
Im building a machine similar to a gun drill. It will have a main spindle (#1) and a counter rotating second spindle (#2) on the other end. All I need #2 spindle to do is turn on and hold a programmed RPM. Which will be different than the main spindle. It's pretty simple.
Posted: Fri Feb 03, 2023 6:21 pm
by tblough
You don't need dual analog for this. Most VFDs have a set speed setting, and on-off can be controlled by the same spindle on signal as the main spindle.
Posted: Fri Feb 03, 2023 7:21 pm
by Rensoc
Yes I guess your right tblough. I was just so stuck on doing it all from the control and would still like to do that but if I can't... I have your idea. They even have remote controls for some VFD i could keep at the control for O/I and changing speeds. Thanks for your reply!
Posted: Sat Feb 04, 2023 7:26 pm
Thanks for explaining exactly what you want to do. This is why I always ask what the goal is, cuz often there's more than one way to go about it!
