I would think this is better, estop should turn it off. Hopefully this can be added to 5.0cncsnw wrote: ↑Fri Jan 27, 2023 4:40 pm ... and, if it is still desired to turn off the laser in case of Fault or Emergency Stop:Code: Select all
;LaserAlignActivate IF SkinLaserAlign_M THEN (LaserAlignPD) IF (LaserAlignPD ^ LaserAlignActivate_SV) && !SV_STOP THEN (LaserAlignActivate_SV) IF LaserAlignActivate_SV THEN (LaserAlignActivate), (LaserAlignLED)
Activate Laser M76func issue
Re: Activate Laser M76func issue
cryptonym, for the CNC PC being used what are the PC specs?
