x-x+ jogging moves in the same direction in the x- direction <resovled>
Re: x-x+ jogging moves in the same direction in the x- direction
mikeintx wrote: Thu Jan 26, 2023 10:40 am Possibly one of the cables got nicked/cut when running them through the bulkhead and is now shorting out somehow? Just a wild guess but these things happen.
Agreed. He needs to see what caused damage to the Acorn DIR output. Miswired or a short....That's why I suggested he check his wiring.
Acorn's are thoroughly tested before leaving Centroid. Most common cause of damage is a mistake or mishap....
mccue.sc
Post by mccue.sc »
these are the only options I have for my axis selections
mccue.sc
Post by mccue.sc »
thanks, i have that info from the report.zip
what i was asking for is screen shots from the clearpath software setup screen for each axis.
use the windows snipping tool. ,type 'snip" in the windows search to find it
consider using a google photo album for your project.
more info here.
photo of the machine please.
What is axis one connected to?
Axis 1 = X
Axis 2 = Y
Axis 3 = Z
Axis 4 = could be rotary or could be a paired axis. what are you trying to accomplish? need machine info/photos!
mccue.sc
Post by mccue.sc »
axis one was x but thats the one that would only move in one direction it is going on a bench mill 3 axis
mccue.sc wrote: Thu Jan 26, 2023 3:21 pm axis one was x but thats the one that would only move in one direction it is going on a bench mill 3 axis
common debug practice is to swap axis motor, swap cables, one at a time to isolate an issue.
mccue.sc
Post by mccue.sc »
is there a way to make the fourth axis the X axis drop down does not give me the option in the wizard
mccue.sc wrote: Thu Jan 26, 2023 4:24 pm is there a way to make the fourth axis the X axis drop down does not give me the option in the wizard
does the motor and drive you moved to the 4th axis work?
