Hi,
On my lathe, I have installed a cnc12 control. I
would like to display or get access to see the values of macro user variables #100-149 and #150-159.
Is it possible?
Acorn cnc12 macro user variables
Re: Acorn cnc12 macro user variables
For variables #150-159, those are contained in the cncm.job.xml file in the c:\cncm directory. For variables #100-149, there is no place to "view" them. You will have to write a g-code program to display them.
You could probably use M200 within a loop to step through the variables and display them. However since #100-149 are reset to 0.0 every time a program is run, I'm not sure what you would learn from it.
Thank you very much for the answer, very appreciated.
I will look at the M200 code.
Hi,
I am not able to find the users variables #150-159 in the cncm.job.xml file
I have include 3 pictures of the oatg and tge first page of the cncm.job.xml file.
In my case the cncm.job.xml file is in the c:cncm414 file?
Anu clue.
Thanks again for your help
Hi,
Anu clue.
Hi,
I have include 3 pictures including the first page of the cncm.job.xml file.
Any clue.
Thanks again for your help.
Any clue.
Hello T2bul,
What are you trying to accomplish, it might be easier to read out the value in G-Code. For Example,
This will produce a message indefinitely saying "Value of #101 is 5" on screen in this example.
These % commands work in the M200 Message m-codes (Not just M225). %f is float number (%.8f) sets decimal amount to 8 digits displayed for example. %c is a character, %s is a string (#300 variables).
Mill Operators manual Section 13.51 goes over these formatted string commands and the use of %f, %c, and %s.
#100 = 0
#101 = 5
M225 #100 "Value of #101 is %.0f" #101
Centroid PLC Tutorial Videos
Static user variables #150 - #159 are stored in "job.xml", not "cncm.job.xml".
Index "0" - index "9" correspond to #150 - #159.
Thanks for the reply.
It includes an very relevant example pointing in the right direction. With some reading on the macro 200-..., I should be able to display macro users variables providing me a tool to debug my macros.
Again your help is really appreciated.
Thanks also for the additional info on the static user variables #150-159 stored in job.xml rather than cncm.job.xml.
