I just swapped out my Richauto B58 HDMI controller to the Acorn. I have Blue Elephant 1318-4 (1300mm*1800mm with 4th B-axis rotary). My machine is equipped with (5) Leadshine Easy Servo 863HBM70H-BZ-1000 with (5) Leadshine H2-2206 Drivers. The ballscrew is an Hiwin 2505 ( 25mm Dia 5mm Pitch) and 1:1 pulley on Zed axis. XY axis has 18 teeth on motor and 90 teeth on pulley (90:18=5:1 ratio), the worm gear is 20:1. My old specs from the Richauto B58 controller was given:
X and Y: 104.37 pulse/mm
Z: 200.0 pulse/mm
B: 111.113 pulse/mm
Consequently, I have attempted to follow the videos, read the forums, manuals, calculator and etc. However, I am still not tuned as the machine should. I tried air cutting existing files and they are to large and exceeds Z limits. I have set my steps/revolutions to 4000 in Acorn, by default from factory they are set the same in Leadshine drivers. I just can not pin point my drive ratio. Any insight will be greatly appreciated? Photos attached
https://drive.google.com/drive/folders/ ... share_link
Need Help to Finalize Calibration for Retrofit CNC 4th Axis Router
- CNC Control System Serial Number: E062347948F9-0324225805
- report_E062347948F9-0324225805_2023-01-13_08-05-12.zip
- I can't promise that my settings are correct. Work still in progress to setup.
- (872.89 KiB) Downloaded 4 times
Blue Elephant 1318-4th axis Rotary, 6hp Spindle with Richauto B58 DSP controller converted to Centroid Acorn
Epilog Helix 50 watt C02 laser 18"x 24" work area
Graphtec FC8000-30" Vinyl cutter/Plotter
Software: Vectric Aspire 11.5v; Rhinoceros 7 with RhinoCAM 2018; Deskproto 7.1v; Autodesk Artcam Premium 2018; CorelDraw 2020; FlexiSign Pro 10.5v
Re: Need Help to Finalize Calibration for Retrofit CNC 4th Axis Router
Boatwrights Workshop wrote: ↑Fri Jan 13, 2023 12:17 pm I just swapped out my Richauto B58 HDMI controller to the Acorn. I have Blue Elephant 1318-4 (1300mm*1800mm with 4th B-axis rotary). My machine is equipped with (5) Leadshine Easy Servo 863HBM70H-BZ-1000 with (5) Leadshine H2-2206 Drivers. The ballscrew is an Hiwin 2505 ( 25mm Dia 5mm Pitch) and 1:1 pulley on Zed axis. XY axis has 18 teeth on motor and 90 teeth on pulley (90:18=5:1 ratio), the worm gear is 20:1. My old specs from the Richauto B58 controller was given:
Z: 200.0 pulse/mm
B: 111.113 pulse/mm
please use a google PHOTO album. the drive link provided does not have access granted so i can't see the photos.
i assume this a rack and pinion machine for X and Y axis? what do you mean by worm gear? do you mean rack and pinion?
You need to do the Coarse and Fine DRO adjustments. Both procedures and some required reading can be found here in this topic. There are links to download the Coarse and Fine DRO procedures as well.
https://centroidcncforum.com/viewtopic.php?f=63&t=1801
And post a copy of a current report so we can see your settings.
Sorry about the error. Yes, R&P setup with a direct drive for the B axis. I will setup the Google album. I have my calibration issue resolved. The Leadshine manual indicated the drives were set by default at 4000 step/Rev but the manufacturer set them at 2000 step/rev. That just threw everything off. Now I just need to double check B axis rotation for calibration and I'm ready to run some test pieces. Thank you
Hi
I have a BE Cnc and am thinking of converting it to acorn. I am a novice at all this and was wondering if you have any suggestions on where to start? Any videos or articles you may recommend
Thanks.
Thanks.
start by taking photos of the machine and posting them to a photo album so we can see what you have and we will guide you from there.
