Manual Jog Function in Acorn cnc
DCAVCNC
Post by DCAVCNC »
Hi. I'm having trouble with the manual jog functions
- I am using 2 HBS86 closed loop drivers on nema 34 closed loop motor for x and y axis and they both work fine.
-I am using a DM542A driver on nema23 open loop motor for my Z axis. Z+ works fine;
-Z- will stop working whenever I use a X- or Y- command before trying to go Z-.
-Z- will then work again as long as I go back and hit the X+ or Y+ manual jog buttons.
I am using the db25 to drive all axis. I did swap Z and Y axis control and the problem followed the changes. Am I allowed to use two different drives?
Any help would be greatly appreciated
-DCAV
Re: Manual Jog Function in Acorn cnc
share how you have them wired. are you using drive enable signals? and how are you using them etc.. and post a fresh report.zip so we can see your settings.
