I just want to make sure I have the axis configuration set up correctly in centroid acorn. I have a Bridgeport Series I mill with a 2 on 1 ration with DMM 750 Servos/DYN4 drivers. I have attached a photo of the settings but just in case you can’t open the file this is the settings.
Steps/Revolutions-8000
Overall turns per ratio-10
Max rate-50
Fast job–50
Slow jog–10
Any help would be greatly appreciated,
James
Axis configuration
- CNC Control System Serial Number: 98F07B461D8E-0601226262
Re: Axis configuration
looks good, nice conservative numbers to get things going. start a photo album of your project post link here and post a fresh report.zip so we can see your current settings.
