Change standard-spindel-direction when in manual mode?
Spartan117
Post by Spartan117 »
Hello,
i am using a lathe with turret behind the part. So most of the turning happens in CCW-direction (M4).
And i often need to let the spindle turn slowly manually, e.g. for scratching or slightly chamfering or else.
So i hit the Spin Auto/Man-button on the WMPG and then the Spin On/Off-button. But then the spindle will turn M3/CW at first, until i change that manually on the VCP.
Is there any way to change the "standard turning direction" for when doing it like above?
So i do not need to hit the Change-direction-button on the VCP?
Regards,
Marc
Spartan117
Re: Change standard-spindel-direction when in manual mode?
Well, i think i'll rate that as a "not possible"^^
Gary Campbell
Post by Gary Campbell »
Press "Man/Auto" button
Press "CCW/M4" button
Press green "Spindle On" button
Or... the not really recommended way: Swap the wires going to the SpinFWD and SpinREV normally open terminals. Remember: All forward commands, manual or automatic (M3) will result in CCW rotation and all reverse commands (M4) will result in CW rotation
You could modify your PLC program to select CCW spindle whenever switching to manual mode.
You could modify your PLC program to use one or two of the Macro keys on the WMPG to select spindle direction in manual mode.
Spartan117
cncsnw wrote: Sun Nov 20, 2022 12:49 pm You could modify your PLC program to select CCW spindle whenever switching to manual mode.
This is what I wanted to do, but I couldn't figure out where to change the plc this way?
Any hints to point me into the right direction? :oops:
I would try to change:
;--Set spindle to manual mode
IF SpinAutoManPD && SpinAutoModeLED THEN RST SpinAutoModeLED
to:
IF SpinAutoManPD && SpinAutoModeLED THEN SET SpindleDirection_M
But I have not tested it
That should do it.
Since the test condition is the same, you can combine them into one statement:
IF SpinAutoManPD && SpinAutoModeLED THEN RST SpinAutoModeLED, SET SpindleDirection_M
Those lines will be somewhere in the neighborhood of line 3400 in the PLC source file, in the Spindle Control section of JogPanelStage.
Spartan117
Uh, sorry, didn't get a notification about this, I will have to check my settings...
Thank you two! I will try that and keep you posted!!
