Hey all, just got my acorn cnc controller to replace a cnc mill that used Mach3 and an ethernet smooth stepper board.
My question is about the Acorn CNC wiring diagram/schematic.
There are 8 outputs going to the relay board, but is OUT1 on H10 the exact same connection as Output 1 on H6 (the DB25 connector)?
Likewise, is DR1 on H2 the exact same connection as Direction 1 on H6? And IN1 on H4 the same as Input 1 on H6?
Thanks!
-Hunter
New user, schamatic naming question
Re: New user, schamatic naming question
Yes they have the same function.
They have the same functions, but electrically they are not "the exact same connection".
You connect to one or the other, depending on the electronic interface you need for the device you are connecting.
- CNC Control System Serial Number: Oak A900946, Oak A901222
I just received my acorn board and had the same question. Per Acorn CNC Installation Manual rev5 11-5-21 Copyright © 2021 CENTROID page 24 the H2 and H3 terminals are for AC servo drives and H6 is for stepper drives. I just ordered the DB25 breakout connector board on Amazon.
Servo drives and connections
I am rebuilding a K2 CNC controller using the acorn board. This controller uses Gecko G320X servo drives. The schematic given for these drives only show the drives connecting to the DB25 connector, can the screw terminal connector be used instead?
Re: Servo drives and connections
no. use the DB25. follow this schematic for Acorn to G320
https://www.centroidcnc.com/dealersuppo ... 088.r1.pdf
The input and output are listed on the schematic.
For drive type you can just create a custom one , Make sure it's set to DB25.
And it works!.
And it works!.
