Page 1 of 4
4.80 upgrade added some pic
Posted: Sun Oct 30, 2022 1:19 pm
by firechief
I have tried to upgrade to the newer CNC 12 4.80 and all I can get is windows tell me is windows cannot access to the drive, path or file. you may not have the appropriate permissions to access the item.
Not sure what to do here. I check and my login has admin rights. I tried to run as a administrator as well and I keep getting the same.
I rebooted the computer as well.
I been using 4.5 a long time at this point.
Thank on the front end.
Tim Smith
Re: Need Help on 4.80 upgrade
Posted: Sun Oct 30, 2022 2:13 pm
by suntravel
Do have updated windows, if not please do so before 4.8 installation.
Posted: Sun Oct 30, 2022 4:01 pm
by firechief
I updated my windows... same thing happens
Thanks for the reply
Tim
Posted: Sun Oct 30, 2022 4:16 pm
by suntravel
Did you make a fresh install, old folder renamed or moved in an other directory ?
Posted: Sun Oct 30, 2022 4:37 pm
by firechief
Trying to do a fresh install.. renamed the cncm folder to cncm-working 450
by firechief
I do not get a setup.exe file in the extracted
Posted: Sun Oct 30, 2022 11:26 pm
by suntravel
There is only one *.exe file in the zip.
Copy this from the zip to the desktop and run it.
Maybe try an other download.
Posted: Mon Oct 31, 2022 7:39 am
by ShawnM
Are you downloading the .zip file using a Mac? Download using a PC only. As Uwe stated, there's only ONE file in the .zip file and it's the .exe file. Are you downloading from here?
Posted: Mon Oct 31, 2022 9:04 am
by firechief
Yes that is where is was downloaded from. The instruction said to click on the setup.exe file, I only get one file, but it is not that. It is a installer file.
by firechief
It was from a windows computer.
