Ether 1616 will not connect <resolved>
Clausing2020
CNC Control System Serial Number: 3639
Post by Clausing2020 »
Hi guys I read through all the posts about this issue. To No success. Yes I can Ping it. Yes there is good Voltage. Yes the computer has the correct IP address. I tried a different switch. I tried a different cable to the ether 1616. The little indicator light goes to 1. any suggestions
Thanks John
report_3484E4260A59-0523226236_2022-10-02_13-13-29.zip
(635.87 KiB) Downloaded 4 times
Clausing2020
Re: Ether 1616 will not connect
ended up being subnet mask was 255-0-0-0 needed 255-255-255-0 I ran long cables and switches to my lathe and it worked so I looked how was that set up. Resolved
