Spindle Benchtest
JayF
Spindle Benchtest
Post by JayF »
Started the benchtest went through the steps and got a error for not setting the max spindle speed to 3000, Changed it to 3000 restarted cnc12 and tried to run the test agiain is says (Bench test appears to be partially completed) So I pressed 1 to continue and I get a (Block N4 not found line 67) I do a press 0 to start over and I get the same Block not found message and I cant get pass this, cycled acorn and restarted cnc12 and get the same message
report_E0623464B717-0628226384_2022-09-30_07-51-09.zip
(781.34 KiB) Downloaded 3 times
Re: Spindle Benchtest
Press zero to start over.
Set your minimum speed as well.
