Axis Setup Issues
cncshaker100
Re: Axis Setup Issues
Post by cncshaker100 »
Thanks Shawn I did get the x axis to work not the rest though, but I will go ahead and install the update and maybe wire it directly from the acorn board to the drive instead of using the db25; as the wiring is pretty much straight forward. I've had this drive for a long time now just look at the dates at the bottom of the manual. I am however upgrading to servo motors I just need these steppers to work so I can make the mounts for the new servos. I'm done for the night a little upset my buccaneers lost today. I see where you're located I'm in St Pete.
