I recently upgraded from X and Y lead screws which used screw compensation to X and Y ball screws. I redid my screw compensation tables and turned on the X table. Regardless of the value in the table for 1", I see no change in the measured error at this position. I am able to tune X backlash and it works fine.
I do run Home after all changes to the table and to backlash.
One thing that is new is my version of CNC12.
Does anyone use screw compensation with the newest version of the software?
Rick
Screw Mapping
- CNC Control System Serial Number: 38D269533454-0111180523
Screw Mapping
- report_38D269533454-0111180523_2022-09-20_05-37-00.zip
- X screw compensation should be enabled
- (933.55 KiB) Downloaded 15 times
Re: Screw Mapping
rick,
hello.
there have been no changes in screw comp in v4.80 works the same as in v4.64 -k
hello.
Re: Screw Mapping
Thanks Keith. Then it is either my new hardware or Senioritis.
Rick
Rick
