Driver issues
Driver issues
Hi all. It looks likeI am having driver troubles. I am using Centroid Acorn. My Drivers are Stepper online DM860 T, the motors are also Stepper online. 6.0A 9N.Nm. The power supply is 48 volts. My problem seems to a homing issue on the Y and Z axis. X will home. Not Y and Z. If I use the X driver connected to SP1 It works. When I connect the X driver to SP2 or 3 they will not home. I'n not sure if the Y and Z drivers are bad or if the acorn board is bad on SP2 and 3. My mill is a Precision Mathews PM25.
- report_3484E41A1E9B-0513226210_2022-09-12_17-59-43.zip
- (675.05 KiB) Downloaded 8 times
Re: Driver issues
(1) 09-12-2022 15:21:49 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:21:49 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:21:56 4032 Reset Cleared
(4) 09-12-2022 15:22:52 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:23:01 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:25:03 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:25:12 199 CNC Started
(1) 09-12-2022 15:25:22 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:25:22 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:25:32 4032 Reset Cleared
(4) 09-12-2022 15:25:50 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:29:16 406 Emergency stop detected
(1) 09-12-2022 15:29:18 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:34:15 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:34:20 199 CNC Started
(1) 09-12-2022 15:34:26 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:34:26 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:34:34 4032 Reset Cleared
(4) 09-12-2022 15:34:51 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:39:24 406 Emergency stop detected
(1) 09-12-2022 15:39:26 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:50:15 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:50:21 199 CNC Started
(1) 09-12-2022 15:50:39 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:50:39 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:50:48 4032 Reset Cleared
(4) 09-12-2022 15:50:58 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:50:58 4032 Reset Cleared
(1) 09-12-2022 15:51:30 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:54:44 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:55:15 199 CNC Started
(1) 09-12-2022 15:55:21 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:55:21 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:55:34 4032 Reset Cleared
(4) 09-12-2022 15:55:45 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:58:38 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 17:54:49 204 Exiting CNC...Normal Exit (66)
https://www.centroidcnc.com/dealersuppo ... ds/270.pdf
Re: Driver issues
Thanks I'll get on it.
Re: Driver issues
and update to v4.80 so we are all using the same version, free support for v4.64 has ended.
and see this post..
https://centroidcncforum.com/viewtopic.php?f=61&t=1451
and see this post..
