Driver issues
Posted: Sun Sep 18, 2022 10:20 am
by cmickey
Hi all. It looks likeI am having driver troubles. I am using Centroid Acorn. My Drivers are Stepper online DM860 T, the motors are also Stepper online. 6.0A 9N.Nm. The power supply is 48 volts. My problem seems to a homing issue on the Y and Z axis. X will home. Not Y and Z. If I use the X driver connected to SP1 It works. When I connect the X driver to SP2 or 3 they will not home. I'n not sure if the Y and Z drivers are bad or if the acorn board is bad on SP2 and 3. My mill is a Precision Mathews PM25.
Re: Driver issues
Posted: Sun Sep 18, 2022 10:43 am
by tblough
(1) 09-12-2022 15:21:49 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:21:49 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:21:56 4032 Reset Cleared
(4) 09-12-2022 15:22:52 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:23:01 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:25:03 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:25:12 199 CNC Started
(1) 09-12-2022 15:25:22 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:25:22 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:25:32 4032 Reset Cleared
(4) 09-12-2022 15:25:50 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:29:16 406 Emergency stop detected
(1) 09-12-2022 15:29:18 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:34:15 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:34:20 199 CNC Started
(1) 09-12-2022 15:34:26 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:34:26 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:34:34 4032 Reset Cleared
(4) 09-12-2022 15:34:51 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:39:24 406 Emergency stop detected
(1) 09-12-2022 15:39:26 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:50:15 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:50:21 199 CNC Started
(1) 09-12-2022 15:50:39 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:50:39 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:50:48 4032 Reset Cleared
(4) 09-12-2022 15:50:58 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:50:58 4032 Reset Cleared
(1) 09-12-2022 15:51:30 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 15:54:44 204 Exiting CNC...Normal Exit (66)
(1) 09-12-2022 15:55:15 199 CNC Started
(1) 09-12-2022 15:55:21 CNC12 Acorn Mill v4.64
(4) 09-12-2022 15:55:21 9033 Reset Initiated, Press Reset to Clear
(4) 09-12-2022 15:55:34 4032 Reset Cleared
(4) 09-12-2022 15:55:45 9033 Reset Initiated, Press Reset to Clear
(1) 09-12-2022 15:58:38 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 09-12-2022 17:54:49 204 Exiting CNC...Normal Exit (66)
For now while you are testing an moving axis around, let's ignore the axis labels. My guess is that the FIRST axis to home is causing electrical noise and causing Ethernet communication errors with the PC. Follow the advice in Tech Bulletin 270 to resolve your communication issues FIRST or you'll just be wasting time with the homing problem.
Re: Driver issues
Posted: Sun Sep 18, 2022 10:54 am
by cmickey
Thanks I'll get on it.
Re: Driver issues
Posted: Mon Sep 19, 2022 2:13 pm
and update to v4.80 so we are all using the same version, free support for v4.64 has ended.
and see this post..
