Hello everyone , I've been using my Acron program for over a year now very happy with the system .
However this morning my pendant screen is not completely showing all data on the screen, al I get is a Wi-Fi signal and battery , sometimes on turn on the device , I get a lost rf display
Top right corner I get ID 50f7 or it could be ID 5DF7
I'm guessing its a control board in the pendant is there a Factory reset button or firmware boot I can try
Any support would be appreciated.
Pendant not Booting semi blank screen
Re: Pendant not Booting semi blank screen
you try replacing the battery in it?
mine does weird stuff on low battery
- CNC Control System Serial Number: 80F5B52C143D-1001215260
Yes couple of time with different batteries , tried holding down different sequence of buttons to reboot . however nothing
you try turning acorn and cnc12 both all the way off and then restarting? what about the pc?
may sound dumb, but you would be surprised how may times the ol turn it off and on works
One other thing to try is to move the transmitter to a different USB port.
reboot cncpc and try different USB port.
Thanks everyone for your replies ,
Its not a wifi signal strength problem or Battery as both indications on the pendant screen show full bars
The Lcd screen on the pendant shows very briefly some connection data text then fades off to blank screen
so the screen appears to work for a few seconds then dies out
can you shoot video of that?onecomp wrote: ↑Tue Sep 13, 2022 11:25 pm Thanks everyone for your replies ,
Okay , we have been able to acquire a new pendant and Wi-Fi antenna all Acron components.
I now feel this is not a pendant issue, We're not receiving signal from the breakout board, I'm not sure how to test this part or exactly what to look for any help would be appreciated.
The cnc machine and program runs fine as a standalone unit. I just don't have pendant access or usability .
Have you got it enabled in the wizard? Does it show up in device manager? If so, remove it, and scan for new hardware to see if it picks it up again.
Scott
