I recently upgraded to 12 v4.80 and everything seems to work fine except the input param for my TT. When trying to run the canned macro for the Z plate, initially I get the following message
I have tried inputs 7, 6 and 4 (for the TT) with the exact same results. I can manually enter "4" for param 11 and the software does see my TT device but it doesnt save the value after restarting the acorn app. All files are the original files from the install. No modifications have been made other than using the wizard to configure the CNC machine. No imports. Using the same Z axis conductive plate that worked in previous install. Not using any probe device, only TT device. When I enter Alt I, the TT device is showing under input 4, just doesnt show up in the Wizard settings. No dropdown selection, no entry in the field, its blank.No PLC input has been configured for Tool Touch Off device. Please enter the PLC input for TT device in parameter 11
Does anyone know why and how to resolve this.
I'd appreciate any help I can get.
