I am retrofitting an Emco PC Turn 55 lathe. The spindle has a maximum speed of 4000 rpm.
What type of encoder for the spindle is recommended considering that the transmission ratio will be 1-1?
A model similar to the Omron E6B2-CWZ1X 1000P/R 0.5M?
Hugo
Emco PC Turn 55 lathe recommended encoder.
Re: Emco PC Turn 55 lathe recommended encoder.
Hi Hugo,
yes, this Omron works with 4000 rpm.
