I have been trying to figure out why my compiler will work perfectly fine on one computer that was setup for Notepad++ the same way as another computer that will give an error previously mentioned in other threads for not being able to find the file. I found that if I run the NppExec script without the quotation marks $(CURRENT_DIRECTORY)\compile.cmd $(FILE_NAME) it will compile properly.
The weird thing is that I can now run the script as listed in TB294 as “$(CURRENT_DIRECTORY)\compile.cmd” “$(FILE_NAME)” and it will now compile properly without throwing an error.
I wanted to put this out there in case there was something that I was missing or if anyone may be searching for this in the future.
Compiling error and potential fix
Re: Compiling error and potential fix
Thanks for the info.
On my work PC I have another solution to get NppExec to compile without the use of compile.cmd
