Keep randomly getting error 9031 DRIVE FAULT! despite there not actually being a drive fault.
I am using the CNC4PC board with clearpath if that matters.
I would like to just disable that error from happening, because it seems to be happening erroneously and is annoying.
what parameter do i change to disable that fault?
Thanks!
how do you disable error 9031 Drive Fault! ?
Re: how do you disable error 9031 Drive Fault! ?
You have one input set as DriveOk. Drag it back to the column on the left
(within the setup wizard, "inputs" section - Utilities > Wizard etc).Gary Campbell wrote: ↑Tue Sep 06, 2022 9:09 pm You have one input set as DriveOk. Drag it back to the column on the left
I have the same setup, and was getting the same errors. For me it was always happening, but only when the slaved axis was enabled by the jumpers on the card.
When I dropped the hardware slaving on the cnc4pc card and instead paired axis A in the acorn wizard, it works fine without errors..
