I installed the new version 4.80 and the control panel does not appear.
this all worked with the previous vesion .
thank you fo your help>
daniel
invisibe panel control with new version 4.80
- CNC Control System Serial Number: ID0035FF621C27-0414214659
- report_0035FF621C27-0414214659_2022-09-05_14-16-23.zip
- (737.23 KiB) Downloaded 13 times
E415F6F70BC3-0318203049
Re: invisibe panel control with new version 4.80
Your screen resolution is set to 1366 x 768 but is recommended to be 1920 x 1080 for correct display.
Whilst writing, your CPU single core benchmark is just 1112 which is well below the recommended 1500
hope this helps
hope this helps
Hope this helps
Nigel
Hope this helps
Nigel
thanks but i also tested it on a recent pc with the recommended specs but the problem is the same.. i reinstalled the 4.64 version and it works fine.
Did you made a fresh install with Acorn 4.80, that means the old \cnc folder renamed or deleted and do not use restore report?
I did a clean full install on another laptop with version 4.80 and the settings I captured on the screen. it does not work …. I read on the forum that another user had the same problem.
Using a laptop and one that does not meet the minimum specs is a double whammy, Centroid does not offer support for laptops. The PC is probably the cheapest component of a CNC build, why not buy the proper PC so you can get free support from Centroid?
I updated my Acorn plasma today to 4.80 with zero issues but I'm using a PC that meets the minimum specs set to the recommended resolution that's not a laptop. I also did a manual update as you cannot restore a report from a different version of CNC12. Good luck.
Post a screen shot of the display with the taskbar visible. Is the VCP just running minimized?
I think it is an issue with your WIN10 setup.
On several 4.80 installs I never have had this problem. PCs were always configured for CNC use.
thank you for his information, I will change PC and I will give you the result.. thank you all for your help
Daniel
Daniel
I did not change pc but we found the solution by changing the regional language to English and version 4.82 works.
