I recently updated my router version to CNC12.80. When trying to set XY0, nothing happens. How do I correct this?
Thank you.
Set XYZ0 not responding since update to CNC12.80.
- report_E415F6F250EF-0205202948_2022-08-27_16-51-10.zip
- (790.42 KiB) Downloaded 8 times
Re: Set XYZ0 not responding since update to CNC12.80.
Check to see what macro is being called with that button and compare it to what was used before. If you had a custom VCP, those can get changed if you don't set in the Wizard that you are using a custom VCP . An easy way to see what macro is used, is to set Single Block and then hit the button, and the macro number will show in the g-code preview. Button macros can also be assigned in the Wizard.
Scott
Thanks Scott,
That solved the problem. The macro was missing. I just referenced from the old copy and selected it through the wizard.
John
John
