Hello my Dears,
I'm just wondering if I could use servos with absolute encoders instead of limit switches for homing. Generally I'd like to avoid homing process every time when I switch on my mill?
Andrzej
absolute encoder instead of limit switches in ACORN
- Hickory CNC Controller: Yes
- CNC Control System Serial Number: 7804732D0434-050819202, 0008DC111213-0120230049
Re: absolute encoder instead of limit switches in ACORN
No. Acorn does not have encoder inputs for drive axis.
some drives have built in homing functions and others have encoder marker pulse output (serach "Zri homing" on this forum) that can be used in conjunction with Acorn Homing.
