.375 Di stock Sample file needed
BillB
Post by BillB »
I’m wondering if there is a sample files repository here on the forum? I looked in the All Acorn documentation but don’t see anything like that and not finding anything in the sample parts Acron directories with a small diameters.
I’m looking for a proven part file that is set up for gang tool lathe I can use for my final machine set up and testing. Since I’m still new to cnc lathe work and programming for turning I would like to start with a NC file that is fully verified. I need a simple file for 3/8 stock with just some simple OD turning and cut off.
Anyone have a file they can share? Still having some issues I’m unsure about and it would be nice to know the programming side of thing is not the issue. I’m programming in fusion so better yet if someone has a fusion file or intercon file is fine to.
Thanks.
Re: .375 Di stock Sample file needed
create it in Intercon. Intercon exports 'good' centroid g code. so this eliminates any issues from post processors etc..
