Hi Guys
I'm new here and new to Acorn cnc12.
I recently hooked up cnc12 acorn board and software on my 4x8 router.
The spindle is controlled from the software.
When I hit cycle start to begin job, the spindle and feed starts together. This results in the tool feeding into the material before the spindle set speed is achieved.
How do I program 5 secs delay after the spindle start (to allow run up to speed), then to continue feeding?
Alex
how to delay feed movement for spindle run up
Re: how to delay feed movement for spindle run up
Place a dwell in the M3 macro after the spindle is turned on
G4 P# ; where # = number of seconds you wish to pause
- CNC Control System Serial Number: "E415F6F77718-1119204061"
Thank you very much.
I'll try it
I'll try it
