I made a manual how I set up C-Axis with clutch and stepper on my lathe.
All files you need to use it are here also.
And this shows how it runs on my lathe:
C-Axis Manual for Acorn with second drive and clutch
- CAxis _Manual.pdf
- (1015.34 KiB) Downloaded 59 times
- DriveCalc.xls
- (14 KiB) Downloaded 20 times
- cnct.hom
- (2.54 KiB) Downloaded 25 times
- acorn_lathe_plc.src
- (286.88 KiB) Downloaded 20 times
- plcmsg.txt
- (2.93 KiB) Downloaded 19 times
- mfunc57.mac
- (747 Bytes) Downloaded 22 times
- mfunc55.mac
- (652 Bytes) Downloaded 22 times
- mfunc53.mac
- (624 Bytes) Downloaded 20 times
- mfunc52.mac
- (850 Bytes) Downloaded 20 times
Re: C-Axis Manual for Acorn with second drive and clutch
nice work! thanks for sharing, i'll make a copy of this thread and put into knowledge base.
