I have the SCF230 and unable to find information for the Spindle ok connection. I followed the 2 wire start and stop connection with the wires and relays. Does anyone have a wiring schematic or is it programming? Appreciate any help.
This is going to a Bridgeport I'm adding acorn with the a 1hp motor.
AC Tech SCF230
Re: AC Tech SCF230
see if you can find the manual to this unit online and post a link here to get things going.
- CNC Control System Serial Number: A81087B4FFCB-0712192265
Re: AC Tech SCF230
Look into using TB-14 or TB-15 open-collector programmable outputs! Parameters 06 and respectively 13 control their function. By default they are set to None (01).
